I'm also pleased that the IPC can now be modified in Forscan. In the table below, any idea what FFV means? The other acronyms seems to be explained in the post #10 except for FFV. I think I need option "B" to enable Forward Distance Alert but wanted to confirm what FFV meant.Thanks for posting this. I didn't know that Forscan was updated and could now write to IPC. Now I have everything like I want it!
I wasn’t sure what it meant either, but mine was set at 7 originally so I used B to keep them both enabled.
That's also an IPC setting:
also another one if you are usually travelling with a passenger / cold / remote start. you can heat the passenger seat too:
720-02-02 - 1st digit of second block:
Sorry newbie here to Forscan. I have downloaded the beta version, have the obdlinkEX cable and connected to the truck...just not sure how to get to the menu option you have screen captured above. thank you for the help!!
Click on IPC (AS BUILT Format) hit the play button GREEN ARROW at the bottom of forscan. Not my pictures below but this it what it should look like.
The remote start climate changes are in APIM
Read this: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
