2010 Limited...When I try to close the rear passenger door, the latch will not secure, and the door will remain "open". The latch isn't frozen as I can move the latch approximately 180 degrees with little effort using a screw driver.
I'm a novice at best, so my question is do I replace the latch, door lock actuator, or something else? I can't seem to find just a latch (p/n 21812/21813) The door lock button will go up and down if I use the switch.
