Skauber
I'm pretty sure the VSM has to be reprogrammed since it has different configurations available like 4 or 5 TPMS sensors and probably other things depending on the trim level. I also think it has to be programmed to the VIN in order to accept communication from the PCM, but I can't say for sure.
If you don't have a Ford VCM (clone or OEM) available and the know-how, I would think the only option you have is to take it to a dealership and explain them the tests you've done, ask them to verify that the VSM is indeed dead or not (could be a power supply issue which has the be diagnosed properly), and then replace the VSM if it is indeed dead.
