onlyexilove
I did a full build on mine and did the EGR delete in the process just to save the cost of the $100+ egr tube. I was planning on doing a tune with the SCT tuner so it worked out well in the end. You will for sure pop the EGR code for faulty circulation. I didn't see a huge difference in the drivability with the code but I didn't push it past a day or 2 before I would use the scanner to reset before I got the SCT tuner. I completely agree with toms89 on the gains you will see from it. Like he said most do it to clean up the engine bay and also do it after installing many upgrades such as headers and top end build or intake. Unless you are finding a true need for doing this and plan on doing even a can tune with something like the SCT SF3 then I would look into troubleshooting the code and replacing the necessary parts.
