Expy Platinum Max - what skid plates to get?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
RCI. They are the best option out there in my opinion.
RacerBX1
SE Michigan
I agree with LokiWolf for the full kit RCI is your best bet. The link you added is just for the Transmission and does not cover the engine, gas tank or transfer case. You could use that and gas tank and transfer case skid plates from the Timberline, but you can’t use the engine cover without replacing the front facia.
VBreithaupt
Do you have to remove both plates to do an oil change? The website says it’s only two screws to change out the filter but what about to get to the oil plug?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
My dealer hasn't complained. I assume they are just opening the small access panel. Pretty sure they would have spoken up if they had to remove the whole plate.
eugene11
Ontario
Good for you! My dealer at quicklane said it was pain is the *ss to get the oil changed and they ended removing and reinstalling rci plates. I have cat flaps attached to tranny plate so that one is heavy, some free weight lift for a mechanic
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Then they are morons! I double checked with mine when I had it in last week for an oil change. They did it via the small access panel with no issue.
My 21 F150 PowerBoost has them too, and not a squeak from the dealer.
