ExplorerTom
so I've only got a single key for my Expedition. From what I understand, it's expensive to get more keys made because I need to go to the dealer to do it.
But here's my idea........
The PATS system doesn't know if a PATS programmed key is in the ignition, it just needs to be near enough to the ignition for the PATS system to read it.
Correct?
So if I got 2 new keys cut at the local hardware store and then secured the existing PATS key inside the steering column, it should work. Right?
Correct?
