front air making rumbling noises past 1
superbo11
nashville
My front air is making rumbling noises after I turn it to 2. It gets louder at each number. It's blowing air fine, its just loud.
does anybody know how I get to the fan. sounds like something might be in the fan because sometimes it sounds like putting a baseball card on your bike spokes. I can tell the blade is ticking something. Not sure how to get in there. Pics would be great. 2003 Expy
ELVATO
Orlando, FL
So you want to remove the blower motor to see if it is making the sound?
S
superbo11
nashville
I'm trying to see if the cage the fan is in is loose or if there is something stuck in there. It blowing fine, but the higher the power the louder it gets and you can sometimes hear like the fan blades are hitting something.
do you know how to get to it.
ELVATO
Orlando, FL
The blower motor is the fan. If you take it out, put power to it, and it make no noise, then you know the sound is coming from the ducting. If you take it out, and it makes noise, then it's the blower motor. Not sure how easy it is to take apart the actual assembly, once it is out, but here are the instructions for removal.
As always, I'm not responsible if you break something.
Removal and Installation of Blower Motor in 2003 Expedition
1. Remove the trim cover to the fuse box (the triangle shaped thing that has insulation on the back.)
2. Remove the passenger side scuff plate.
3. Remove the passenger side lower A pillar trim.
4. Position the carpet aside.
5. Remove the blower motor.
-Disconnect the wire connector and place aside.
-Remove the screws.
-Remove the motor.
6. To install, reverse removal instructions.
JUST4FUN
Admin
Il
I had the same problem there was a bag in the max air intake
which is under glove box ,
if you swich from normal a/c to max .you can hear the air change from outside to inside
look under the dash and follow your ears
S
superbo11
nashville
do remove the power from the fan do you pull that off or is there more to it. It's hard to get a look at it. Do you you pull it lose.
Jefes_Shyt
