All,
I went to remove the front DS so I could replace (or eliminate suspect part) due to bad shake/vibration in steering wheel. The front u-joints appears to be original so they need replaced either way.
Question is how do you removed the 4 screws hold the plate on? I put used a 12pt 12mm socket, but couldn't get them to budge. I put some PB-Blaster on an let it soak overnight, as it was late when I was finishing up.
1. Do I need to lock the driveshaft someway or can I put it 4WD-LOW to accomplish that. (Fear was hurting gears in xfer-case)
2. Also, is there a way to access the top bolts by rotating the shaft? I'm not used to the "electronic selector." All my other rigs, had a mechanical shifter that I could put in neutral.
*Edit - 99 Expy no 2WD selector.
Thanks.
Thanks.
