I was talking about na not in your case but as related to fordandpolaris post.
Not trying to argue with you or discredit you in anyway i know you know what your talking about. Ive been out of the seen for a while so dont know a whole lot about the new stuff.
So do our trucks look at a table when in open loop and a ratio (14.7:1) when in close loop? Im a former DSMer and this is how the ecu works on them.
Also with Eclipses, AIT is a BIG factor in A/F! The timing on these is adjusted by the ecm according to the MAF reading! More air means more timing!
I wasn't really trying to argue with you either but what you stated was contrary to what I understand. It seems the dsm vs ford tuning strategies may vary significantly.
I have been studying and applying tuning for my expy for near 18 months now with sct software. I probably have 50 different variations of programs in my file and have looked at the tune for hours on end. I have read Engine Management Advanced Tuning by Greg Banish and The Ultimate Ford EFI Tuning Guide by Don LaSota as well as SCT 2010 Training Manual several times. I also frequent the SCT Pro racers tuning forum to try and learn as much as I can.
Does this make me an expert? No!! Not by any means and I learn more each day but I do feel I have a good grasp on the basics of tuning with the expy by now.
To answer your questions.
In open loop it does utilize fuel tables which are based off load and rpm then it adds in modifiers if any. IAT is not one but engine coolant temp is. Since fuel trims are directly effected by load and rpm I adjust the tables accordingly to get the desired air/fuel ratio. So as I get into boost the load goes up and it looks up the desired lambda based on that area of the table. Open loop is commanded based on load and/or throttle position.
Ford does use the O2 sensors to maintain stoich in closed loop and constantly toggles fuel trims and stores in short term trims then eventually long term. This allows for minor differences between like motors and wear. Stoich for gasoline is 14.64 as ford defines it. The rest of the world... 14.7 Its in closed loop probably 95% of the time.
Timing tables are set up by load and rpm as well then some if any modifiers. Load is directly related to the mass of the air entering the motor. Also the higher the load the less timing. But then one of the modifiers is the IAT and it can add or subtract timing based on it.
