Fuses in '03
NCEXP
I'm trying to troubleshoot my radio installation. Symptom: no power on new radio.
I haven't checked the harness with my multimeter yet, but i have checked 2 fuses #7 & #22, per the owners manual. Are there any other fuses related to the radio?
It's an '03 that had the cd/cassette combo and rear audio controls, if that matters.
Green03, i'm looking at you here.
Thanks.
lakmflx
P.C.B
Are you certain you connected the radio to the correct wires from the factory harness? ( if you spliced off the factory connector) Or did you buy an apadter kit that plugs into the factory harness and then to the radio? I'll bet that if you spliced off the factory harness that you have your wires crossed.
green03
College Station, TX
I would also ask if you used an adapter harness or spliced into the factory. If it is an aftermarket harness you need power on both the red and yellow wires with the key on...
Matt R
N
NCEXP
Crutchfield provided a nice harness. The meter shows no voltage at the factory harness!:confused:
PaulMedik
