Going to give HP Lubricants PCEO oil and engine cleaner a try, maybe their ATF
gtr09
Midwest
Over on BITOG they are giving pretty good statements about this oil, and many report running it hard for 10-20k between changes without issue. It's pretty expensive but if you really did go 15-20k between changes it's a wash. I probably won't go past 10 but we'll see.
The plan is to drain 1 quart on my current oil which has about 2k on it and replace that quart with their engine cleaner. I'll run that for 1k or so and then switch over to their PCEO.
Since the car is tuned now I figured better oil can't hurt.
Got some more reading to do but also might try their HP ATF Teal when it's time to change the transmissions fluid, they state it's compatible with Ford MERCON ULV. Has anyone tried these out yet?
