I've had an ongoing problem with my air conditioning system. It works great, gets ice cold, then suddenly cycles itself off for a minute. This process repeats itself constantly. I thought it was moisture in the system, so did a vacuum and recover the freon, reserviced etc. This seemed to work, but the next day the problem was still there. I suspected the forward expansion valve.... so I changed that and the problem is still there.
So today I found this ford TSB reference number 04-5-9. It's titled "CLIMATE CONTROL- INTERMITTENT LOSS OR AIRFLOW FROM A/C SYSTEM AT HIGHWAY DRIVES- VEHICLES BUILT PRIOR TO 3/16/2004".
Well reading through the TSB, the problem is the thermostatic switch is mounted on the expansion valve and it gets too cold, causing the system to shut down before the evaporator has a chance to cool the cabin down.
The TSB provides a kit part # of 4L1Z-19E992-AA which relocates the thermostatic switch to the evaporator core. This prevents the system from cycling on/off so frequently. With the newly mounted switch the system will work like most normal a/c systems do, and only shut off if the evaporator ITSELF gets too cold and is at risk of freezing up.
The standard low pressure switch is still in place so there's no risk of the system freezing and starving the compressor of it's freon.
That kit part # is ok on Google, but not found on Motorcraft website. I'll check the dealer at lunch time to get a price and the kit hopefully.
