Neil Matlock
I have a 2000 Ford expedition that will not start with turn of the key. My battery is good, my starter is good, and ignition switch is good. I can get the car to start by jumping the starter relay terminals. When I do that I have a check engine light with o/d flashing. There is intermittent power to stereo, washer fluid level light. the check engine codes are for O2 sensor bank one and two sensor two, and trs. When I checked voltage to the transmission range sensor there’s nothing. I have replaced the interior fuse box and gem. The only fuse that doesn’t have power is the OBD2/ lighter which I believe is fuse number three. On the relay there is no power to red/tan wire at any key position. Any help would be really awesome.
My thoughts are leading me to the pcm or bad ground. The factory service Manual I have sucks and any recommendations for one that has a complete wiring schematic would be helpful.
