How To Replace Body Bushings
acolic
Hamilton Ontario Canada
Hi
On my list before winter is to replace my truck's body bushings.
If anyone's done that before I'd appreciate some advice.
Besides the seats and the carpet does anything else need to be removed to access the bushing bolts.
Anything special required to remove the front two bushings next to the motor?
Thanks for the advice.
SnuffThePunkz
BC, Canada
Bolt goes up through the support, and there is a nut on top. Pull the liner back and you'll reach it easily. Once the bolt is off put a little pressure with a floor jack and a block of wood to lift the body. All you need is like a 1/4" and the bushing will slide up through the hole and out.
A
acolic
Thanks.
The one I’m worried about is the front one near the rad. Does it have to control out?
