Spoiledhappywife
5 years? I am so envious- we get 2 with the type of heat we experience here. I am glad to know how to gain access should that happen.
Thanks for sharing!
Thanks for sharing!
Using the Key Blade
The key cylinder is under the driver side door handle. To access the cylinder:
- Pull the handle and hold it.
- While holding the handle outward, identify the cylinder and insert the key blade into the slot.
In other words, I think it is just "revealed" when you pull the door handle.
- Actuate the cylinder to unlock or lock the door.
^^ That'll do it.
Short story somewhat related, might help somebody someday - Parked at the airport a few years ago in an F150. Locked keys inside like normal and returned days later to a dead battery. Coworker was on the same flight, parked nearby and he determined he could momentarily place a jumper wire from his truck to one of my 7-pin trailer connectors while I dialed the door keypad to unlock the doors. The outlet cover showed which pin was constant 12V, which normally charges your trailer battery while towing. Its the pin at about the 1:00 position. Once the doors unlocked he pulled the jumper off. I was then able to pop the hood and do a conventional jump start.
