Install inside passenger door handle.
mbed
SE PA
I'm looking for a video showing me how to replace the inside passenger door handle. I've checked YouTube but didn't find anything.
Thank you!
I changed them pretty easily. Don't have video but the handle pivots on a post with a spring to reset it. If u can open handle u can see it. Bottom section of post is set in and upper section is under a tab that you can raise slightly/ just enough with flat blade screwdriver to slide too in or out. May be easier if you remove trim piece around handle but remember if absolutely required. Hope it helps
1955moose
My friend just removed his door panel recently. Theirs a screw under the plastic triangle on top of door, you'll also have to remove door light down low. Theirs a screw there. I believe after that you pull up on panel to release. The removal and replacement of the handle is pretty easy from there.
Jefes_Shyt
