american steel
idle on these engines should be 600RPM.
with these older engines buying these stupid little tuners are a waste of time and money especially when the 5.4 and 4.6l aren't that great at producing power or torque by todays standards.
if you want more power you'll just have to do a small head port job a little bigger cam grind not the duration just extra lift and headers also a bigger throttle body.
I've seen so many bad motors because of tuners. piss poor timing valves kiss the pistons etc etc. its a waste.
there is no need to change ECUs if a tuner is giving you issues because of wires then you need not use it. tuners don't give much for these older motors.
