IWE Replacement
drjeff
arizona
I have a 2018 Expedition XLT and I just had to replace the IWEs after 26500 miles. There is a TSB report number 19-2252 that explains the cause and procedure for replacing. This is after replacing 5 shocks, taillight lens, second row seat, and reinstalling SYNC. I am rebuilding....
99WhiteC5Coupe
You said you had to replace the IWEs?
Wasn’t the work covered under the new car or power train warranty?
D
drjeff
arizona
The IWE is the Integrated Wheel End. There is the vacuum system that keeps the transmission in 2WD. The default is 4WD and if the vacuum system begins to fail, IWEs make contact trying to go into 4WD. You hear a brief grinding sound upon startup. The IWEs begin to wear out from the contact.
Tmg115
Dfw
What type of ass backwards design is that??? What ever happened to the good old actuator in the transfer case
Boose
2017 Platinum EL
NJ
pretty sure they've been like this forever on the Expy... I know my 05 had this as well. I wonder what they changed on them over the years. I never had a problem with my 05, nor my 17.
Soliyou
OK
The transfer case still has the actuator and clutches. The IWEs disengage the wheel so they the front drive shaft and diff do not rotate and reduce fuel economy (you still end up with minor rotation).
But you are right, why would you still use vacuum in this era! Problematic and cheap design.
Boose
2017 Platinum EL
NJ
I disagree.... I have a combined 200K plus miles on these with my trucks. Never had a problem. Granted, I don't know if they changed the design on the 18 and up though.
Soliyou
OK
The design didn’t change much. There is a check valve that fails and allows the hub to lose vacuum.
You just got lucky. When the time comes to fix an air leak in the system, you will know what I mean :))
