Gary Waugh
I just fitted the pads, am not aware of any bedding procedure? Also did not touch the proportioning valve, but the pads were new along with the disks. Why would we touch the proportioning valve? what is the correct bedding procedure? I usually push the brake pistons back into the calipers, remove the old pads and spring plates, fit the new pads and spring plates, refit the calipers, then pump the brakes until the pads have touched the rotors and the pedal becomes stiff and then I go and test drive the car by performing a couple of gentle stops and then a few more harder stops and that is it. Would love to hear/learn more.
