Let's See Those Lifted / Big Tire Gen 4s!!
Expy Gator
Florida
Trying to make what ford won’t!
2023 Timberline running Gen2 Raptor upper and lower control arms, tie rods, Fox. 3.0 non live valve shocks i mounts using the Camburg Raptor conversion buckets. Rear consists of the stock Timberline strut with a machined 2” spacer and longer control arms to center the wheel and tire. 37” BFG K02s on Raptor 37 package wheels. BajaForged roof rack and KC Pro6 lighting. Next is to modify a set of Raptor fender flares to fit!
I was looking to modify some Raptor fender flares until I looked at the Baja Forged fender flares and I liked them - I mentioned it a few weeks ago to see if anyone wanted to do a group buy but not much interest here. I have some on order.
FabLab05
Where did you find longer control arms? I wouldn't mind centering my rear wheels after my ReadyLift.
The only company offering any is RoughCountry, i called them up and told them what i needed.
FabLab05
I talk to the fine people over at BF from time to time and a few weeks ago i was told they need 10 more people to fill the preorder and once filled it will take another 12 weeks to ship out. I can build my set much quicker and cheaper
Expy Gator
Florida
Interested - and would like to see how you modify the Raptor flares to fit
Ice Man 62
fort smith, Arkansas
Not a 4th generation but I'm running a 2.5 rear and 3.5 front leveling kit with 33x12.5x17s on my 2003 expedition.
fomoco1964
San Diego
So after buying my 2022 XLT Max 4 months ago, I knew the first thing I wanted to do was lift it. I was looking for lift kits online when I cam across @95cobby and this forum. I decided to do the same lift and go with the Bilstein 5100 F150 4X4 front shocks on the stock setting and the Expedition rears on the second (.5") setting. This combination gave me 2.5" of lift in the front and .5" of lift in the rear. I also installed a set of Icon Delta Joint UCA's. I'm running the stock 20x8.5 wheels with a 44mm offset and 275/65r20 (34" tall) BFG All Terrain KO2 tires. I was a little worried that my tires would rub the UCA's because of the backspacing on my factory wheels, but the Icons fit perfectly and I have plenty of clearance.
GixxerJasen
DFW TX
Is it me or still not completely centered on the rear? Or is it just the angle?
thegerb50
