Like an idiot
toms89
technical advisor
MD
So sounding like a total idiot...and on cheap prescription drugs..oil filter on the block..I assume that other cooler up front is power steering? Oh why I have you laughing and your attention...LOL...I put a new battery in last night and drove it today...what I noticed was upon start up and driving it showed 14.1 - 14.2 on my Edge steady...I dropped my wife at the grocery store and waited about 15 to 20 minutes in the truck and let it idle..and it went down to 13.7-13.8 but when i started driving again and got it cooled off wit the breeze it went back to 14.1 14.2...Im concerned going to Florida with the extreme heat and dont want to cook a new battery...you thoughts?
Likely rpms and load. Alt will not put out as much juice at idle..
H
heathan
North West, Florida
Ya actually I found the oil filter right away. I should've pulled the trannyfluid pan to change the filter but I've heard stories about this. This weekend me and my buddy are planning on flushing the radiator and I'm thinking of buying some new headers for it.
Thermo
technical advisor
heathan, take it from us, you will get what you pay for when it comes to the headers. You can buy all the shorties you want and that is what you are going to end up with, short of power. They may gain you a little bit, but not a whole lot. You will get more power with taking that money and investing it in a good exhaust system. You want more power, get your hands on a set of long tube headers. That is the only garanteed header power gain you will get.
H
heathan
North West, Florida
lol its funny you said shorties, that's what me and a friend where lookin' at. But I was actually gonna by the ceramic coated higher end ones....but I'm still lookin' around. I am not good when it comes to knowledge of horsepower and all that with cars. I'm actually wanting to adjust it for optimal mileage and power..I know that they are two opposite sides of the coin but I'm looking for a happy medium.
Is there any suggested reading you guys got??
Thermo
technical advisor
Long tube headers!!!!!!! take it from us. You can have both a cake and eat it. The trick is not using the gas pedal too often. the long tube headers are going to give you more power due to a scavaging effect due to the design of the long tube headers. At the same time, because the scavaging is occurring, you are getting more fresh air into the cylinder, allowing for more complete combustion and more power. Since you are cruising at a constant speed, the power needed to keep the truck at a certain speed is constant, you can burn less fuel because the cylinder is burning more completely, getting more power out of the same amount of fuel.
Now, you decide to use the loud pedal a lot, you can plan on single digit mileage too. This is where self control comes into play.
Another thing you may want to consider is switching over to e-fans. This isn't the end all modification, but by getting rid of the mechanical fan and going over to e-fans, your motor will warm up quicker (which will get you out of running the motor rich sooner), you will have less losses from loads on the belt (no more fan producing drag), and you will see on average about a 6 hp gain along with 8 ft-lbs or torque gain (across the whole RPM band, not just at one end). But, like I said with the headers, you get what you pay for. I've seen guys cheap out on their systems and after a year or so, they start having fan issues which then leads to overheating. If you want to learn more about this, let me know. I've been down this road.
Also look into the "Gotts mod". takes a little bit of time, but if done properly, can net you some power for free while improving the mileage of the truck (any questions, just ask).
Another thing that I would tell you to look into is modifying the air box. This is something I did and tested it on a dyno. All you do is you remove the funnel portion of the air box that goes between the metal band that joins the two halves of the air box and the fender. I netted 1 hp and 10 ft-lbs of torque. Big numbers, by no means. BUt, in this case, every little bit helps.
Between a combination of modifications that I have done, I am still able to maintain 13 mpg running 37" tires.
H
heathan
North West, Florida
Ok I'll have to check that out. RIght now my focus is my bikes, but I'm wanting to get a headstart on learning about my truck and mods I can do.
Goff69
