Dorzak
Cold day for California, it was 29°F when I woke up. About half way to work low tire pressure warning goes off. Visual inspection looks a little low, on all 4 tires.
After work, check the pressures. All of them are at 32 psi. Label on the door recommends 35 psi cold. I just had the tires rotated at the dealer because I had a free "Works" because they hadn't done an oil change while it was driven by staff. Either I have a leak on all 4 tires leaking the same amount, or the dealer inflated them to 32 psi. Then when it was cold this morning that dropped below whatever threshold for the TPMS.
