Chrismdean09
What are people metering at as far as db and hrz. I hit a 148.7 with two 15s on music peaking at 38hrz. Just curious what all you other sound enthusiast are hiting
And who says it doesnt sound good at those levels because it sounds dam good at that level with no distortion.
Yeah I understand that it also depends on the box you have as well mine is tuned to 32hrz peaks at 38 and lets the subs breath and cool at little better. Im thinking 4 15s should put me over a 150 but idk yet we will see come next fall.
Double the power.... Double the cone size... Gain +3db.
Are you saying that them being tuned at 32hz helps cool the subs better? What woofers are you running? What is the internal volume of your enclosure and what is the port size and thickness of the wood? Also what amp are you running to these woofers?
