Name/Part number for this sensor on master break cylinder
sonyhome
nv
Can someone ID this sensor so I can look for the part and get a new one?
Also do you know how to remove it without breaking anything, and will the break fluid spill out?
I am trying to troubleshoot my cruise control not engaging.
In some post, someone mentioned this 2A fuse as being a potential problem for the cruise control. Looking at the connector, it's filled with break fluid (I think), and the break cylinder looks wet too. I replaced the whole wire harness with the 2A fuse, and it seems to have blown on me again. So I suspect it did so because the sensor (or whatever it is) is bad.
JerryT
FL
Motorola OE Part#sw6350 you can find it at Advanced Auto or any parts dealer.
hwy73
South Jersey
That pigtail was added as part of a recall. That leaking sensor was causing F-150's and Expeditions to catch fire while parked and shut off. Seems that sensor is "hot-at-all-times" and when leaking brake fluid would destroy the insulation, a short could occur and start a fire.
jessiev
