no A/C
acrbill
Chicago
I just picked up a 98 Expedition and realized that the A/C does not work.
I'm pretty sure the compressor is engaging, since the engine reacts when I put the switch to a/c.
Neither of the a/c lines under the hood gets cold.
I put the rear a/c on, and took off the access panel on the rear drivers side. The lines and block were ice cold.
That is what confounds me.
I did a search and found some mention of the blend door when the front a/c didnt work.
I cant see how that would effect the lines from getting cold.
Any insight would be greatly apprciated by me and the poor salesman I might just kill for selling me a car with broken a/c.
Thanks in advance!
Chesterfoxes
New Jersey
If the compressor is running and the lines aren't cold/sweating, no flow through the front system. TXV (thermal expansion valve) in the core might be stuck shut. This valve opens and closes according to the cooling load on the system.
Paul
A
acrbill
Chicago
Turns out it was the compressor. I noticed that it was cycling on and off. I figured the system was low on freon and caused the compressor to act up. I'm glad the dealer techs are smater than me!
Glad I got it fixed...... Just in time for fall and winter!
Goff69
