No power at fog light module 2019
nick22t
Nc
2019 Ford Expedition Limited
Factory led fog lights
Ive recently noticed that neither one of my fog light are working. Green indicator on dash illuminates but neither light comes on. I checked to see if the module and get 12v and they’re not getting any power.
What should I check? I have forscan and adapter which I used to turn on Bambi mode in the drop down menu.. this is what led me to realize that neither was working in any scenario
Hellwig
are you sure the light bulbs good? I am aware you've checked power module. But just in case, you know.
N
nick22t
Nc
No I don’t even bother with the bulb once I realized there’s no power to the module
N
nick22t
Nc
That was my first thought too but couldn’t find anything in the owners manual in either fuse box.. My understanding is that there isn’t a fuse because it’s controlled by the bcm..
99WhiteC5Coupe
Perhaps use ForScan to return to the original setting and see if that resolves the fog light issue?
Anthony DeVor
Maryland
You are correct that there is no fuse it is controlled through a FET within the BCM. The BCM on my 17 Expy and 16 & 18 F150's have two fuses from the SJB in the engine bay that provides power to the BCM - one fuse for the drive side lighting and the other for passenger side lighting. If I remember correctly 1 is a 50amp & 1 is a 40amp. I do not remember the fuse numbers off hand. Usually if a FET has been shorted there will be a code visible in Forscan.
M Bennett
