I'm going to refrain from bashing anyone BUT Loki beat me to responding to this: "Ford, GM and Chrysler all tried turbo charging in the 80's. They all phased them out. Why? Now 25+ years, Ford, comes out with the Eco-boost..."
The reality of the times was that nearly ALL of the motorcycle and car companies dabbled with turbos in the early to mid-eighties....I OWN ONE today! EVERY single one of them suffered from "turbo-lag" which is the delta in time between the moment the throttle is applied, and the moment that boost is produced. The accepted school of thought at the time was that the closer the turbo is mounted to the exhaust valve, the less turbo-lag. The mighty Kawasaki 750 Turbo mounted the turbo in front of it's transverse 4 cylinder engine getting within 7" on the exh valves, was fuel injected(also a first for bikes) yet if failed in the public market as did every other turbo'ed car or bike. People didn't not want to pay a premium price for a vehicle that didn't immediately react when they twisted their wrist or pressed on the gad pedal. In the case of the Yamaha, the "standard" n/a ran for $2,980...while the turbo edition not only ran $4,190, it weighed nearly 55 lbs more, had lower off-turbo compression and was a pig in terms of power/weight....off boost. (6-7 years ago I bought my Yamaha 650 turbo and after being taken under a guru's wing, learned how to modify and reconfigure the boost control to produce 18PSI and it's a blast to ride. Off turbo, it's still the same pig that it was but my girlfriend doesn't like to go fast so she never twists the throttle wide open...and it never scares her because boost is only built if there is a large delta between throttle position and present throttle opening. )
Years later in the 90's, Mitsubishi built a twin turbo, the 3000GT that also suffered from a bit of turbo-lag and it wasn't cheap...but ask anyone who owned one and they will tell you that it was a rocket, once the boost built.
All the cars failed for the exact same reason....increased complexity & cost but turbo lag was the killer of sales.
Saying that, it's quite clear today what caused their downfall then and what has been learned about the implementation of turbos in vehicles since then and the solution that Ford chose to use in the 3.5TT.
When I first began shopping to replace my '03EB I saw the 3.5tt and looked into it's configuration and was slapped in the face with the design changes that Ford employed....it was very obvious! One glance at the exh manifold and anyone who works on engines of any type will recognize their solution ....and knowing just a little about fluid dynamics and bingo, they shrunk the exh passages to speed up the velocity, thereby causing the turbine to be spinning at even slow engine speeds....and wa la...in one minor design change and they eliminated the dreaded "turbo-lag"!
Not only did they eliminate it but they did so at a low enough cost so as not to be forced by the accounting guy to jack the price up!
Hot air does not absorb moisture or fuel as well as cold (if it did, we would inject hot air instead of cooling it first) but it does cause the moisture to condense when it's cooled. This is where the early 3.5's ran into some issues. In high humidity situations(like MD every summer) the moisture would condense in the intercooler then be flung onto the MAF and other sensors distorting the readings and causing the issues he described. Do you know what "the fix" was? It was to quite simply drill a single 1/4" hole on the bottom of the intercooler to allow the condensed moisture to drip on the ground....problem solved! It was such a small hole that in the big picture, it didn't even affect engine performance!
As Drew has so expertly stated, his engine is a beast....but it's also an EXPENSIVE beast that he paid a premium to own....more power to him! He obviously knows enough about his engine to know that you don't want to shut down a hot turbo system but is smart enough to allow the cooling oil to do it's job before he shuts the engine down.
Most of us have seen the Mercedes commercial where they show the engine running in a rig...and the entire exhaust and SC turning beet red.....yes, a turbo (or SC ) can get quite toasty but since they run in an oil bearing, they aren't beet red on the inside but if you run and turbo'ed engine hard you need to allow it to cool down before shutting it down or you risk the oil burning off and you having a dry-start the next time you start it...and that's not a good idea in any engine which is exactly why Drew lets his run a bit before shut-down.
Case in point....I own a slew of 2 stroke street bikes, some very fast. I remember racing these back in the 70's and at the strip, we would watch as a guy ran a race, winding it out till the end of the 1/4 mile then shut the throttle. Problem with that was he was shutting off the supply of oil lubrication along with the gas...and the engine would seize. I watched as the same thing happened in the vintage races at Ohio last summer.....the poor guy got to the end of the straightaway, chopped his throttle and seized his engine and was out of the race.
jeff
