Big Brian
I montorthe tach all the time when towing
Only 2 positions? Seems that the extreme high should be one too. High oil pressure can be as bad as low. Has anyone see the pressure get closer to the H?As stated it does not really show oil pressure, it just indicates if there is pressure or not, it doesn”t show how much pressure, the gauge only has 2 positions, 0 or about 70%. If you need or want to know the actual pressure you need to fit an aftermarket gauge..
only 2 positions like a dummy light. It's either on or off.Only 2 positions? Seems that the extreme high should be one too. High oil pressure can be as bad as low. Has anyone see the pressure get closer to the H?
