You could try the procedure in the service manual to "Intialize" the liftgate.....
Power Liftgate Initialization
NOTE: If the power liftgate feature is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE: The power liftgate may not operate under the following conditions:
•A low voltage or dead battery
•A disconnected battery
•Repairs/adjustments have been made to the power liftgate rod, power liftgate motor, liftgate hinges or liftgate striker
If any of these conditions has occurred, the power liftgate must be reset.
NOTE: The power liftgate may also be initialized by carrying out the liftgate/trunk module (LTM) self-test.
NOTE: The battery must be disconnected for 20 seconds before the module will enter the initialization mode.
1. Disconnect the battery.
2.Wait 20 seconds and reconnect the battery.
3.Manually close and fully latch the power liftgate.
4.Power open the power liftgate by using the key fob or control switch.
5.Once the power liftgate is fully open, close the power liftgate by using the key fob or control switch
Matt
