hnnybnny
Hi everyone so I was pulling out of the store parking lot and my 2003 for expedition just shut off I stopped put it in neutral crunk it back up or started right back up and then died again and then nothing after that. When my key is on there is this constant buzzing from the fuse box on the passenger side. Then on my message center it displays PRNDL ERROR WHEN I RUN A SYSTEM CHECK IT DISPLAYS SYSTEM CHARGING ERROR FUEL COMPUTER DATA ERROR ENGINE SENSOR DATA ERROR and my fuel pump just continues to run instead of shutting off after you turn the key on. What could be the cause of all of this?
