Pulsating while Braking
Discussion in '1st Gen - 1997 - 2002' started by FLJ01, May 12, 2012.
  1. FLJ01
    FLJ01 Member
    16
    Aug 25, 2007
    Recently on my 2001 Exp. 4x4 I have been experiencing a pulsating from the right front end. when braking. The brake pedal doesn't pulsate. I have since replaced both rotors, pads and calipers. Steering wheel stays straight. It has 90K miles.
    Don't know where to look next. Any help would be appreciated
  2. rburch
    rburch Full Access Members
    1,434
    Jun 10, 2010
    Independence, Mo
    It could be several things! Is the ABS light on or blink when the it pulsates? Could be the caliper also.
  3. FLJ01
    FLJ01 Member
    16
    Aug 25, 2007
    There is no ABS light on.
    The caliper was changed because I thought it may have been causing it, but it did not change.
  4. sgtowing
    sgtowing Super Mod, Supporting Members Supporting Member
    5,507
    369
    Jan 30, 2011
    Valrico, Fl
    It is something in the suspension. Sounds close to the "Ford death wobble". Check shocks, springs, tierods, bushings and anything else including a-arms, control arms and swaybar.
    Sent from my DROID BIONIC using Tapatalk 2
  5. FLJ01
    FLJ01 Member
    16
    Aug 25, 2007
    I will check the suspension as you indicated. It doesn't wobble. Can you provide more details on this "ford death wobble"? Thanks
  6. RobertNol
    RobertNol Full Access Members
    99
    Mar 14, 2012
    Hernando, Fl
    I'm not sure if the ford death wobble is the same as what I had but I'd call it a death wobble. When ever I would hit the breaks I would get a very rapid and strong wobble in the steering. Mine was caused by the passenger side lower ball joint.
    Its was a very strong wobble, it felt as if it was going to shake the entire truck to death and it was very dangerous.
    Ill be following this because i still have the same pulsating while breaking. I am very sure my shocks are bad so ill be checking them first :)
  7. BakerEdition
    BakerEdition EF Chaplain
    2,115
    53
    Aug 6, 2011
    Sounds Like a Ball Joint....I just had a F-150 that did the same thing...was a lower ball joint...right side too!
  8. FLJ01
    FLJ01 Member
    16
    Aug 25, 2007
    Will have a look at the shocks and lower ball joint.
    Thank You
Share This Page
