Question about PCM Resetting...
S20Workstation4
Hyde Park, NY
Hello All,
Following FordTechMakuLoco's PCM reset video, I reset the PCM and followed the normal correct procedure. I let it idle for 15 minutes, and then went on a drive, allowing it to shift through all the gears with light throttle application.
I had to put the throttle about 80% due to an incident; I was about 11 miles into driving after PCM Reset. Since I almost floored it, would that mess up the learning process, to where I would to have to re-do the procedure again?
Thank you,
-Joseph
