Rear Air supspension C1726
GaryB
Atlanta GA
Hello,
I have a 2010 Expy limited I just purchased a week ago. Noticed the other day that the back was sitting lower than the front in the driveway. Its got 162k on it, so I was already thinking of replacing the struts. Then I noticed this has an air suspension in the rear, and my bluedriver showed a C1726 code. What should my starting points be for diagnosis? I already looked and saw that the height sensors are indeed attached. Thanks for any insight.
Lorlainie
Valley Mills, TX
I have a 2010 Expy also. Been dealing with this issue for a few years now. 2 years ago I replaced the rear airbags and just last month they failed again. We finally replaced with regular struts and am so glad we did. No more compressor running and no more dropping in the rear. Ride is a little different but acceptable.
HawkX66
Semper Fi!
VA/MA
Hello,
Do you hear the air pump running? It's right behind the passenger side head light.
G
GaryB
Atlanta GA
Strange thing. I pulled the RH height sensor off the ball stud, and raised it with my hand, and the compressor kicked on. Lowered it and it shut off. Took the other one off, and they both move freely. Then, I shut off the air suspension while it was pumped up to ride hight, then let it sit overnight. Did not appear to loose any air. Reset the code, and it hasn't come back on (been about a week).
On another note, the truck rides like a boat. I've got new loaded strut assemblies coming that I'll put in this weekend. I'm hoping it's just the front. Then alignment.
HawkX66
Semper Fi!
VA/MA
Glad to hear it doesn't sound like anything major. Good luck.
G
GaryB
Atlanta GA
OK, I think I figured out what is causing it.... I had some time with no issues, then I made a pull up an on ramp, WOT, from 20-70 or so. Right after that it came on, to check air suspension. It went off again after the next key cycle. I haven't checked with the scan tool, but I'm guessing it's that same code.
G
GaryB
Atlanta GA
Well, I've had a few more "check Air suspension" warnings on the dashboard. Still no idea what's causing this. Through Forscan I can run the service test, and it checks out fine. I'm new to Forscan, so I haven't figured out yet if it will let me open the vents manually.
Going to pull the air compressor out and take a good look at it this weekend. Anything else I should be checking? I've never seen it sag, I'm almost wondering if it can't vent.
Flexpedition
midwest
Hitch up a trailer with some tongue weight and go for a short drive, or put a few hundred pounds in the rear cargo area. (note: with the liftgate open, I don't believe the suspension will raise or lower. Keep this in mind if loading or unloading heavy items. once closed and after a short duration, the self leveling will occur)
the_plugger
