Will this work for me?
I am interested in the answer to this question as well. I have a Factory DVD player out of an 05, and would like to install it in an 03. I have the wiring harness, and the wiring schematic,the roof bracket, and I have tested the DVD player using the ground, and the Constant 12V, Switched 12V, and Illumination. Everything is working properly other then the Audio in the headphones. I am only interested in installing it for use with the IR headphones for the kids, but there seems to be almost no audio at all in the headphones. If you turn them up all the way, you can barely here the audio. My question is, is the Factory Head Unit some how amplifying the IR signal? I would think the IR signal would be constant as long as the DVD is playing. Am I missing something, or is it possible this DVD player is broke? Is the audio being amplified from the Factory Head Unit, and being re directed back to the IR outputs through Corporate Audio Protocol A or B? Any help is appreciated, Thank You!
