RustyH
My son and I tackled a major rebuild of the front suspension of our 98 Expedition 4X4.
We were only able to complete the drivers side and hope to complete the passenger side tomorrow.
We're replacing the upper control arms, bushings and ball joint, lower ball joint inner and out tie rod ends.
Our 98 has nearly 300,000 and has a Trailmaster 4 Inch lift kit.
The biggest reason for it took nearly all day to replace the drivers side parts was because I kept discovering I didn't have the proper tools, including a 36 MM axle socket and a 1 1/8" box wrench to remove a castle nut on the lift kit.
Before starting the job, I watched this video, which helped give me an idea of what I was in for.
http://www.youtube.com/watch?v=vkXYXgWBzSg
Believe me, watching an 8 minute video will only give you an idea of what you're in for.
This is not a job for the faint of heart or someone not mechanically inclined and it requires a lot of brute strength, so unless you've got the right tools and the experience, I wouldn't attempt this unless you don't mind being without your truck for a couple of days. The good news is so far, the only injury is a smashed thumb, which while sore, shouldn't impede me finishing the job.
The only reason I did it was because cash is short and I didn't want to spend a grand or so replacing everything. As it stands, so far I figure I've dropped around $300 in parts and specialty tools and I still have to pay someone for doing the front end alignment.
More in a couple of days. Wish me luck
