Replace ‘17 door keypad
Longtalltechsan
Does anyone know how to do this? On this model the keypad is in the long piece of trim under the window. Mine isn’t working and won’t light up. To make it worse I lightly pulled on the 9/0 button and it popped right out and wouldn’t stay in when I put it back. I found the part online but getting it out and the new one in seems a little involved.
Ryan L
Houston
Yes, it’s a bit of work. Need to remove the door panel, then remove the trim piece to which the module is attached. Hopefully the plastic clips survive, or MacGyver a way to re-mount the trim securely.
The closest YT video I can find is a 3 parter. Here’s part 1:
Good luck! Let us know how it goes.
