cel? if not just keep runnin if all fluids are good etc. keep an eye on your oil pressure and temps. if something is wrong you should pop a cel soon. could be cop, plug or fuel injector giving you trouble
mine idles ruff sometimes when im parked for a while, at light usually. then i go and its fine. check you vacuum hoses behind the throttle body. that would be a good place to go to if it gets worse.
