lunchboxlust
I finally got the transmission installed and the truck wont run. It starts tight up like it should but wont idle. I can give it some gas and it kinda runs but it backfires and sounds like it is only firing once in awhile. Not drive-able at all. I have checked some vacuum lines and found none to be unplugged one was cracked so I cut it and reinstalled. The exhaust is mostly rotted off so I'm about to cut it off. I'm wondering if some critter made a home in it because the time I kept it running for a few minuets I could smell a burning smell that reminded me of when I had a rat nest in the exhaust of a lawn mower.
It had almost 3/4 of a tank from around last March so I put stabilizer in it and threw 5 gallons of 93 non ethanol still no help. I smell that it is rich after trying to keep it running and it back fires a whole lot. I talked to a buddy and he said to test the egr, map and the oil pressure sending unit.
It has oil pressure but from the reading I did I can only test the egr and map with the truck running and it wont do that so I'm at a loss of what to do. Any and all info would be greatly appreciated.
1999 ford expedition, 5.4 4r100
