Suspension
USMCFB
Minnesota
I have a 2000 Expedition and I found a 6" FABTECH suspension that i like or a 5" RCD suspension. The Fabtech says that it will not work with factory 4 wheeldrive.
1. Does anybody have any thoughts on brands? And does ProComp make a suspension lift for this vehicle?
2. How do i make the FABTECH suspension work If I have factory 4 wheeldrive?
Canadian Expy
Toronto ON
Welcome !!
I have a Fabtech Kit sitting waiting to go in. Mine is AWD all the time.
Another member Walnuts has a Fabtech kit in his and he aslo has AWD all the time, no problems. Mainly you might need a new rear driveshaft made with a CV style joint. or you could do the BROWN WIRE MOD. this allows you to switch into 2WD. or you might not have any problems.
Fabtech and Zone are the only 2 kits that are 6" and that I would recommend .
What size tire do you want to use?
