TonyR0206
I’ve got two questions regarding my 22 Stealth with the 15.5” screen:
-Is there a way to synchronize the rear temperature with the front temperature? (So when I change the temperature, it changes it for the whole cabin? I’ve only been able to do them individually, even in “auto” mode.
-for the rear temperature, if I use the slide and slide the temp indicator all the way to the top in the “High” position, on its own, the slide moves down two or theee degrees. If I slide it back up, it slides back down. Only if I use the +/- does it stay in the “high” position. Does this happen to anyone else?
Any input is appreciated!!
