ZombieSoldier
What pressure are you running in your tires? Are you running what's in your door jam or a different pressure?
easy way to fine tune it.... set a PSI... then watch your tread...if you have excessive wear in the middle PSI is too high.... if the outsides wear more then its too low... thats what I have done for years on my lifted truck....
what your looking for is an even wear across the entire tread
