To all those with a 3.5 x 2.5 lift please read.
ONEBADMK8
NJ
Thanks in advance.
I have put on the 2in front and just washers in the back to clear my 295/75 18's 2 years ago. Now I have 35 x 12/50's and want more height for clearance.
My question is this. is it harder or a different procedure for the taller lift?
Specifically in the front?
The 2in was an easy slap job, just 3 top bolts uca ball joint, tie rod and sway bar. BUT it seems I am going to have a much tougher time with the 3.5 spacer getting the strut back in or no?
Also my front ball joints were SHOT so I am replacing the a arms too, that should be cake with all the other crap off I am assuming.
Also broke a wheel stud UGGHH hope that is accessible too.
tallsville
LA
If you did the 2in lift you shouldn't have have problem with 3.5. The spacer lift isn't 1:1, So its only a little bit bigger then the spacer you already have in there.
ONEBADMK8
ONEBADMK8
NJ
Went perfectly. Looks killer and the General Grabbers are amazingly quiet. I still have 5 sets of grabbers available, let me know. $800.00 a full set.
Goff69
