Topping off Orange Antifreeze with Yellow Antifreeze
Utah Driver
Utah
My 16' needed to be topped off after 7 yrs. I went to the Ford dealership and they gave me the Yellow antifreeze. I quickly found out that I have the orange antifreeze. After a little bit of internet forum searching I found out that the orange antifreeze is GM dexcool. I also found out the newer spec yellow Ford replaces the orange and is compatible. So basically there are two options unless you go for other aftermarket brands.
ManUpOrShutUp
PA
Ford stopped making the orange, so yes, the replacement is yellow.
U
Utah Driver
Utah
Yeah, but the important thing here is that the newer spec yellow can be used to top off existing orange antifreeze (of an older spec) without a drain and flush. Thats a different thing than your statement.
ManUpOrShutUp
PA
It really isn't. The yellow has replaced the orange in the product lineup (and did so years ago). If they weren't mixable, there would be no orange replacement. It was formulated, specifically, to be mixable with the orange as the factory maintenance schedule involves a drain/fill, not a flush/fill.
U
Utah Driver
Utah
Except that it specifically says on the bottle not to mix with any other antifreeze. That is why I posted the Ford bulletin that says that you can mix with other colors of anti freeze even though the bottle says otherwise.
U
Utah Driver
Utah
Be glad that the motorcraft antifreeze play well together. I have a 13 Chrysler and the Chryslers had massive problems with heater cores plugging and non mixable antifreeze. The earlier days of dexcool had sludge/jelly problems when mixed wrong. I dumped the OEM Chrysler antifreeze and went with the autozone extended life in my Chrysler a long time ago. It's compatible with all types so I don't have to worry about someone topping it off with the wrong stuff.
Hopefully the industry will settle down and agree on something soon. It's nuts. A quick google search will get you out in some forum of nerds arguing about OAT, POAT, NOAT, and IAT antifreeze. Then there is truck antifreeze. All we sell at work is TRP extended life and it is rated at 1,000,000 miles 8ys. It is OAT.
