Transmission Service / Fluid, Filter, Gasket for 4W70R transmission
ELVATO
Orlando, FL
I have a 4x2 and my sticker says U, which is the 4R70W...
CSVT#49
**** Rapids
Just thought I would add to this...
Transmission code 'B' is for a 4R75E I had a hard time finding this as the typically Ford decoder does show transmission type. Also for what it's worth my Expedition has the selectable 2H, A4WD, 4H, and 4L.
EDIT: This is only for 03-05 Expeditions. In 06 for some reason they switched the trans code to 'Q' for the 4R75E.
98EXPY 5-0
PA
Ok, so going by those instructions, just dropping the pan is roughly 5 qts?
I think I also read that if there is Mercron 3 or 4, I can add 5, but if it's already got Mercron 5, I can't add 3 or 4? Since I don't know whats in it, I guess the safest bet is to just use Mercron 5?
Is it better to lift the front or rear of the Exped. for proper draining?
gator
florida
Thought I would comment on this...
When searching for filters it seems, according to the guides, that it's pretty cut and dry...
2 wheel drive = 4R100
4 wheel drive = 4R70W/4R75W
I guess the guides could be wrong, but the filters look pretty different.
I have a 4X4 with the E code that is supposed to be the 4R100
trdragons44
nj
4r100 is behind the 5.4, 4r70w/75w is behind the 4.6(in most cases)
dpember1990
