Trip Meter Resets
djljr
Any idea why my trip meter has started resetting to 0.0 on startup? The battery still starts the vehicle but I can tell it is laboring and probably won't make the summer; could the drain at startup cause the reset? The total mileage meter is operating properly and if I leave it set there, the trip meter does not reset; only when in the trip mode. Weird!
JUST4FUN
Admin
Il
are the needles for rpm and mph doing a sweep(on startup)?if so get a new battery real soon . on startup the batt is dropping below 8 volts thus everything is doing a reset
ELVATO
Orlando, FL
When the battery is disconnected on mine, the tripmeter will switch to the odometer and display 0 when switched back to it.
You could take it to Advanced/Auto zone, and have them do a battery test for free.
D
djljr
Elvato and Just4fun,
I suspected the battery was the culprit and replaced it this past weekend; problem solved.
Thanks
sharprd65
