Muddy Bean
Sorry to be posting a flurry lately. Truck has been a little high maintenance as of late. Had it in the shop here for a trans fluid change. Shop noticed and pointed out to me an obvious oil leak at drivers side turbo. They are hearing bearing noise from it as well. I’ve heard a noise for a little while now but never thought anything of it. Sounds a bit like rattling wax paper. Hard to describe. Anyway, making phone calls right now to get the turbo replaced and seals redone under my extended warranty which expires in 3000 miles. Coolant is also leaking at one of the junk jiffy tite connectors on the same turbo so that will be fixed at the same time. In the past two days, truck has also gone into idle limp mode three times due to the known throttle body electronic issue posted here. So, I’ll think we are going to have it all done at the same time, under warranty and be done with it until next time. I only have 116,000 miles on this truck 90% hwy...and yes I’ve towed a 5,000 lb trailer 13,000 miles this year, but I sure hope I don’t have a ton of this stuff post warranty expiration.
