NTX2008XPY
I'm new to the group but have used it to search many topics. Thought I would share a solution for a vibration or shudder i was experiencing when i would give light throttle while traveling above 45 MPH. I originally thought it was a slipping TC but it had no other signs of slipping in other RPM ranges and a tranny shop checked it and said it wasn't throwing any codes. Thought it might be misfiring but OBDII reading showed no misfires. Thought it may be out of balance tires but no vibration if i coasted at those speeds. Change Tranny fluid and filter, added LUBE GUARD shudder fluid and still no difference. Changed rear difff fluid, no change. Checked U joints and they were still good. Turns out it was the right rear axle. The upper CV joint had started coming apart internally. There was evidence of oil/grease leaking around the upper CV case/joint.
Finally took it to a shop by the house they confirmed that it was failing and replaced the axle. Happy to report smooth sailing at all speeds now.
Some of the signs to be aware of:
Intermittent clunk when going from Drive to Reverse.
Intermittent squeaking when rolling a lower speeds.
Coming off highway and coast from 60 MPH to 40MPH, slightly press the gas and it felt like it was in the wrong gear, like a shudder.
I hope this helps someone else that may be chasing the same issue.
