Druid
So I recently purchased a 2007 Expedition EL Eddie Bauer with the HD tow package. The truck has less than 100k and I have been working my way through basic maintenance. Now I'm turning my attention to the wheels/tires. Currently the vehicle has 255/70R18 tires, which are worn, and 18x7.5 wheels from a 2009-2012 F150 (the ones with spokes that look like box-end wrenches). I'm now looking to update the tires, going slightly wider/taller. Basically 275-305 in width, 33-34 height. This will be accompanied by a set of Rancho Quicklift struts (advertised +1.5" front, +.75" rear) and likely require newer, wider wheels (for 285+). This is fine, because I really don't like the look of the rims that are on there.
Among the possible replacements are various take-off rims folks are selling locally on Craigslist, plus a few on-line options, and I have two questions.
1. Several of the options I've seen and liked are 18" or 20" F150 or Expedition rims from later model years (2015+). I know the lug nuts from these years changed from M14/2 pitch (pre-2015) to M14/1.5. I've also read that Ford wheels require Ford-specific OEM nuts. Does anyone know if the early M14/2 OEM lug nuts will work with the later rims?
2. Another possibility is downsizing to 17" rims from the 2013-2014 Raptor (with slight rear trimming of the axle). It seems like these should fit, but can anyone confirm? When I check my current 18" wheels for clearance around the calipers and dust shield, I have less than 1/2" of space. This makes me a bit nervous about fitment, and had me wondering whether the HD tow package came with slightly larger brakes or something. I'm guessing the clearance problem is really about the design of the current 18" wheel, but would love some reassurance if it's to be found.
Thanks any and all for help or input.
Cheers,
Drew
View media item 6440
Cheers,
Drew
