rex450se
I have a 1998 with the 5.4L that has been running great until today. It ran fine this morning and then this afternoon it started and then died. Since then, it will start and then die. You can keep your foot on the gas to keep the rpms up but as soon as you let off it will die. I checked the vacuum assembly from the PCV valve. I think it may be the IAC valve or the MAF. To check the MAF I removed the one off of my 2003 4.6L and it did not fix the problem. But, though they have the same plug, they are not identical so I don't know if that proved anything or not. I don't want to purchase parts that I don't need to so are there any other ways to try to test these items to narrow it down? Are there any other suggestions? Thanks in advance.
Victor
Victor
