Mojave Jack
Hi Y'all, well trying to keep this old gal going;
I am the second owner of a 1997 EB 4x4 5.4 that I have driven since it had 36k miles...it is now at 200200. Mostly trouble free...
As it is getting up there, it has leaks, so I watch fluids pretty well, except for the water/coolant, see thread...
My tranny has for the last 5 years or so intermittently had morning sickness, where it slips when it is cold in drive, then it is fine...servicing fixed that issue about 50k back...
5 weeks ago, the tranny fluid appeared to be low, so I added two quarts of type f atf; oops, but it was all I had at the house...I thought it wouldn't make much of a difference as innerweb said it was the same except the lack of friction modifiers...
Well, couple weeks after that, my od light started blinking, and then it would shift hard without an audible bang from 1-2...and this wasn't even every day, just whenever...
Then, last thursday, after driving it with same blinking od light, but speedometer/odometer and no check engine light on...friday morning I started her up and she had a dancing speedometer, odometer worked normally, but she was slipping so bad in 3-4th...no check engine light and the od light never blinked. but still functioned well...as I had the kids in a canyon, i dropped them, went to pboys and checked fluid level hot, it was dry...so I put in 4 quarts and some lucas antislip (as it felt like my 65 mustang did when the torque convertor just didn't have enough fluid in it).
this didn't solve the problem. after some research and today after slipping badly to kids and a check engine light that finally came on code p0500 vehicle speed sensor $10 at my shop I use, i talked with them and they started with maintenance...we drained old fluid, flushed tranny with 15 quarts, changed the filter and put in a 30 dollar vehicle speed sensor that goes on the tranny unit itself...the mechanic test drive revealed harder shifts, no slipping like it was in neutral, check engine light not cleared yet, no light on overdrive blinking, but also no speedometer, not even dancing like before...
I drove it today around, but it shifts hard from 1-2 and 2-3, I did have some slipping once while in od 4th like it was in neutral, but now it doesn't slip as much and no speedometer, cleared code, engine light came on again for p0500, and now it clunks with sounds, and even goes into to first abruptly when slowing at a light...
It does feel like the car is faster, freer, like the filter was clogged, but can't tell because no speedometer, odometer, and therefore no trip computer for average mpg etc...QUESTION FINALLY, sorry but details, is there another vss on the rear axle of this 97 expy? Is this typical to drive one day, then the other morning have all the problems 8 hours later? thanks for any advice or input!!! John
